commonfieldspopup
The commonfieldspopup statement pops up a list of common fields, and changes the current field specifications when a field is chosen from this menu.
This statement pops up a list of common fields, and changes the current field specifications when a field is chosen from this menu. It is triggered by pressing the star next to the field name in the Field Properties Panel. If the star is right-clicked (or the control key is held down), a new field with the selected name is added at the end. If the Shift key is also held down, the new field is inserted at the current position.
- abortalldialogs -- closes all open dialog windows (with prejudice).
- activegrid -- manages the operation of a grid that controls a series of options.
- addmultiplerecords -- Adds multiple records.
- addrelatedrecord -- adds a new record to the related database corresponding to the current database.
- adjustobjectspacing -- adjusts the spacing of selected objects in a form.
- adjustobjectspacingdialog -- opens a dialog sheet to adjust the spacing of the currently selected objects.
- analyzedialog -- opens the standard Analyze dialog.
- append -- appends a text string to a field or variable.
- appendline -- appends a text string to a field or variable on a new line.
- applescript -- executes an AppleScript.
- arraydeduplicate -- removes duplicate elements from an array (see Text Arrays).
- arrayfilter -- processes each element of an array with a formula (see Text Arrays).
- arrayintegersort -- sorts all the numeric elements of a text array in proper numeric order.
- arraynumericsort -- sorts all the numeric elements of a text array in proper numeric order.
- average -- calculates averages and sub-averages for the selected records in the current field.
- batchassign -- assigns a bunch of fields/variables to another bunch of fields/variables.
- blockkeyboard -- temporarily suspends/resumes keyboard input.
- blueprintlibraries -- generates blueprints for all procedure library databases.
- blueprinttool -- handles clicks in the Blueprint Tool (graphic mode).
- bringforward -- brings the selected form objects one layer towards the front.
- bringpanoramaforward -- brings Panorama forward, making it the active Application.
- bringtofront -- brings the selected form objects to the front.
- buildfavoritesmenu -- builds the *Favorite Databases* menu.
- buildwizardmenus -- scans the wizard folder to build the Wizard menu and submenus.
- cgitest -- tests a CGI procedure.
- channelactivemodule -- returns the currently active module for a channel, if any.
- channelcall -- calls a procedure in the active channel module.
- channelcatalog -- creates a list of all channel databases (including the path for each database).
- channelgetdictionary -- returns the current settings for a specified channel.
- channelinformation -- returns information about a specified channel.
- channelload -- loads a channel module.
- channelmodules -- returns a list of available modules for a specified channel type.
- channelopen -- opens a channel module for editing.
- channelpath -- returns the path of a specified channel module.
- channelprocedures -- returns a list of procedures available in a specified channel.
- channelsetdictionary -- saves new settings for a specified channel.
- channelswitch -- switches the active channel module.
- channeltypes -- returns a list of available channel types.
- checkforupdates -- performs the same action as the *Check for Updates* menu item.
- clear -- deletes the contents of the current cell without touching the clipboard.
- cleartypeahead -- clears any typed ahead characters that have been pressed while a procedure is running.
- clearundo -- clears out the undo stack, eliminating the ability to undo any previous action.
- clipboardimagesave -- saves an image on the clipboard as an image file (.jpg, .png, etc.).
- closeallasyncprogresswindows -- closes any asynchronous progress windows.
- closedialogwindow -- is used internally by the rundialog statement.
- closeserverfile -- closes the current database (used on the server).
- collapse -- hides the detail records associated with the currently active summary record.
- collapsetosummary -- collapses to the next higher summary level.
- columnstatsdialog -- opens the standard Column Stats dialog.
- Comments -- A *comment* is a note inside a program.
- comparedictprocedures -- compares all the procedures from a dictionary with the procedures in a specified database.
- console -- sends a message to the console log.
- constructcalendar -- creates the form elements for a monthly calendar.
- constructfieldssheet -- opens a sheet to add/insert multiple new fields into the database.
- constructformdataeditors -- creates a column of form elements for editing data fields (or variables).
- constructlineitems -- creates a grid of line items.
- constructlistmatrix -- creates a text list or matrix in the current form.
- constructmailinglabel -- creates the form elements for printing mailing labels.
- constructreport -- creates a report in the current form.
- constructtabpanel -- creates a tab panel in the current form.
- copy -- copies the contents of the current field onto the clipboard.
- count -- counts all non-empty data cells for the current field.
- countsummaries -- counts summary records.
- crosstabdatabaseselectoriginal -- selects original data corresponding to a cell in an exported crosstab database.
- crosstabpopup -- handles a click on a crosstab text list.
- crosstabselectoriginalformula -- returns the formula that will select the original data associated with a crosstab cell.
- customdialog -- customizes the appearance of the gettext and getscrap dialogs.
- cut -- deletes the contents of the current field, copying it onto the clipboard.
- definehotkeys -- defines one or more Hotkeys.
- degree -- tells Panorama that all angles input to and calculated in trigonometric functions are in degrees rather than radians.
- delay -- loops for a specified period of time.
- deletechildren -- deletes all the records in another database that have a value in the key field that is equal to the key value.
- deletehotkeys -- deletes the hotkeys in a specific scope.
- deleterecchildrenwarn -- warns you before deleting the current record from the active database and all the records in another database that have a value in the key field that is equal to the key value.
- deleterecordandchildren -- This deletes the current record from the active database and all the records in another database that have a value in the key field that is equal to the key value.
- dialdigits -- dials one or more digits.
- dialphone -- dials one or more digits, adjusting for area codes, country codes, etc..
- displaydata -- will display data in a large dialog with a scroll bar.
- displayhtml -- will display a dialog containing HTML. You can control the size of the dialog, as well as several appearance options.
- dragarrayorder -- tracks dragging of a cell within a Matrix or Text List object, then reorders the array associated with that object accordingly.
- dragwithinmatrix -- tracks dragging of a cell within a Matrix or Text List object.
- duplicatefield -- duplicates the current field.
- editfavoritesdialog -- handles the Favorites button in a dialog.
- endshowlater -- resumes the immediate display of text and graphics after it has been deferred with the showlater statement.
- executeapplescript -- compiles and runs an AppleScript.
- executeapplescriptformula -- executes an AppleScript, with embedded Panorama formulas.
- executeperlscript -- executes Perl code.
- executesudounix -- executes a UNIX shell command using *sudo* (root) privileges.
- executeunix -- executes a UNIX shell command.
- expand -- reveals the next level of collapsed detail records associated with the currently active summary record.
- expandall -- reveals all collapsed detail records associated with the currently active summary record.
- expressionstacksize -- does nothing.
- extendedexpressionstack -- does nothing.
- extensiontype -- returns the type code of the specified file (if any).
- favoritedatabasedialog -- opens the standard Favorite Databases dialog.
- favoritesbutton -- handles the *Favorites* button in a dialog.
- field -- tells Panorama to move to the specified field for the current record.
- fieldblueprint -- creates blueprint code for the specified field.
- fieldblueprintsheet -- opens a sheet to edit the blueprint of the current field.
- filecatalog -- creates a list of files in a folder, including any subfolders of that folder
- filemenubar -- creates a custom menu bar or context menu for the current database (see Custom Menus).
- findopendialog -- opens the standard *Find & Open* dialog.
- findrelated -- finds information that matches the current record in a related database.
- finishtimecheck -- finishes a performance monitoring session.
- fixsuperdates -- fixes Panorama 6 SuperDates in current field.
- folderinfo -- calculates the total size of a folder, and the number of files in the folder.
- fontinformation -- accesses information about a font (see also the fontinfo( function).
- formblueprint -- creates blueprint code for the specified form.
- formblueprintsheet -- opens a sheet to edit the blueprint of the current form.
- formconstructordialog -- opens a generic form constructor dialog.
- formobjectblueprint -- creates blueprint code for specified form object.
- formoptionsblueprintsheet -- opens a dialog sheet to edit the blueprint of the current form options.
- formulabuffer -- does nothing.
- formulamerge -- merges data into a template.
- formulasum -- calculates a total by scanning a database, returning the accumulated sum of evaluating a formula over and over again for each scanned record.
- getaddress -- divides the last line of an address into separate components.
- getcitystatezip -- divides the last line of an address into separate components.
- getfieldproperties -- returns a dictionary that contains all of the properties of the specified field.
- getformulatext -- converts a formula into text without special quote characters.
- getname -- divides a person's full name into separate components.
- getscrap -- will display a dialog with a text entry area. The entered text is placed in the clipboard.
- getscrapok -- will display a dialog with a text entry area. The entered text is placed in the clipboard.
- gettaglocations -- locates all matching tags within some text.
- gettext -- will display a dialog with a text entry area.
- gettextdialog -- displays a configurable modal dialog that asks the user to enter an item of text.
- getwebcolor -- will calculate an RGB color from a Netscape style web color.
- globalmenubar -- creates a custom menu bar or context menu for all windows (intended only for internal use by ProVUE Development).
- gotofielddialog -- opens the standard dialog for jumping to a specific field (in the Fields menu).
- grabformula -- evaluates a formula using data from another database.
- groupdown -- divides the database into groups, with a summary record at the end of each group. The groups are arranged in descending order (high to low).
- groupup -- divides the database into groups, with a summary record at the end of each group. The groups are arranged in ascending order (low to high).
- hide -- temporarily disables the output of text and graphics.
- hidepanorama -- hides Panorama X, making all windows disappear.
- htmlextractimages -- extracts the image URLs from an HTML page.
- htmlextractlinks -- extracts the links from an HTML page.
- htmlformitemnames -- returns a list of form input elements (*INPUT* tags, etc.) within an HTML page.
- importdatabasedialog -- opens the standard Import Database dialog.
- importform -- imports a form into a database.
- insertnewproceduremark -- inserts a new mark into the current procedure.
- ipaddress -- returns the current IP address of the computer, or "" if not connected.
- joindialog -- opens the standard Join Database dialog.
- launch -- launches an application.
- loadlibrary -- loads a library database into memory.
- loadurl -- loads a resource from the internet.
- macoscomputername -- returns the name of this computer.
- makeabsolutepath -- converts a relative path (relative to the current database) to an absolute path.
- makefilesecret -- closes all of the windows associated with a file, but keeps the file open in memory.
- makemergeformula -- makes a formula from a template.
- matrixbutton -- helps implement buttons in a matrix object.
- matrixbuttonhelper -- helps implement buttons in a matrix object.
- matrixclick -- will run the code belonging to an object that was clicked within a matrix frame.
- matrixclickedobjectid -- helps implement buttons in a matrix object.
- matrixredrawclickedcell -- redraws the matrix cell that was just clicked.
- maximum -- calculates the maximum and sub-maximums for the current field.
- minimum -- calculates the minimum and sub-minimums for the current field.
- morphalldialog -- opens the standard MorphAll dialog.
- morphdialog -- opens the standard Morph dialog.
- newdatabaseusingblueprint -- creates a new database from a blueprint.
- newformusingblueprint -- creates a new form from a blueprint.
- newsearchgadget -- creates a search gadget in the current form.
- nextvalue -- advances a variable or field to the next value in a list.
- normalexpressionstack -- does nothing.
- noundo -- does nothing (it used to disable undo).
- nowatchcursor -- does nothing, and is only retained for compatibility with earlier versions.
- nslog -- sends a message to the console log.
- openfarform -- opens a form in another database.
- openlivecoursecalendar -- Opens the Live Course Calendar window.
- openmapwindow -- opens a window displaying a map of a location.
- openpreferenceswindow -- opens the Panorama Preferences window.
- openserverfile -- opens a database (used on the server).
- opensoftwareupdatewindow -- opens the Panorama Software Update window.
- openviewdialog -- opens the standard Open View dialog (in the View Menu).
- openviewsearch -- opens a View Search window.
- openwebmap -- opens a web browser window displaying a map of a location.
- openwizard -- opens a wizard, just as it would be opened by selecting that wizard from the menubar.
- pagesetup -- displays the page setup dialog.
- panoramaappvisibility -- allows the Panorama X dock and menu bar to be hidden.
- paste -- pastes the contents of the clipboard into the current field.
- pausespeaking -- pauses any talking that is currently happening.
- perl -- executes a Perl script (program).
- php -- executes a PHP script (program).
- popup -- makes a pop-up menu appear anywhere on the screen.
- popupatmouse -- displays a pop-up menu at the current mouse location.
- popupbelowbutton -- displays a pop-up menu in response to clicking on a button.
- popupbutton -- displays a pop-up menu in response to clicking on a button.
- popupbynumber -- makes a pop-up menu appear anywhere on the screen.
- popupclick -- displays a pop-up menu at the current mouse location.
- popupdoublefieldchoices -- displays a pop-up menu listing values in a specified field, with submenus containing values from a second field.
- popupfieldchoices -- displays a pop-up menu listing values in a specified field.
- popupsharingmenu -- pops up a menu for the toolbar sharing icon.
- postadjust -- adjusts the value of a numeric field in another database, by adding (or subtracting) a number.
- posttorelated -- posts data in the current record to the corresponding record in a related database.
- posturl -- loads a resource from the internet, with form data.
- print -- prints the database.
- printonerecord -- prints the the currently active record.
- procedureinserttext -- inserts text into the current procedure.
- proceduresetselection -- changes the text selection in the current procedure editor window.
- provueserverisup -- checks whether provue.com is online and operating.
- python -- executes a Python script (program).
- quit -- quits Panorama.
- radian -- tells Panorama that all angles in trigonometric functions should be calculated using radians rather than degrees.
- recompiledatabase -- recompiles all of the procedures in a specified database.
- recompilelibraries -- recompiles all Panorama libraries.
- refreshcrosstabdatabase -- refreshes a crosstab database.
- refreshsummarydatabase -- refreshes a summary database.
- removeallsummaries -- removes all summary records.
- removedetail -- removes data records from the current database, leaving only summary records. It can also delete low level summary records, leaving only higher levels.
- removepreferencevalues -- deletes one or more preference values.
- removesummaries -- removes summary records from the current database.
- resumespeaking -- resumes speaking after a pause.
- reverseorder -- reverses the order of the records in the database.
- revert -- reloads the last saved version of the database from the disk.
- ruby -- executes a Ruby script (program).
- runcustommenu -- runs the *.CustomMenu* procedure.
- rundialog -- uses a form as a template to display a modal dialog window. The statement supervises the operation of the dialog until it is closed.
- rundialogmenus -- enables custom menus in a modal dialog.
- runmodifyfill -- runs the .ModifyFill procedure (if it exists).
- safefileerase -- deletes a file if it exists, but no error if it doesn't exist.
- save -- saves the database to disk.
- saveacopyas -- saves a copy of the currently active file under a new name. The original database remains open in memory under its original name.
- saveas -- saves a copy of the currently active file under a new name. The original file remains unchanged.
- scanlibraries -- scans all libraries and registers all of the custom statements in them.
- scanlibrary -- scans a library and registers all of the custom statements in it.
- scrapcalc -- calculates a formula and stores the result in the clipboard. (Note: The same effect can be achieved by putting the word *clipboard* on the left side of an assignment.)
- scriptbglog -- specifies a path/file for output from STDOUT from embedded programs run in the background (Perl, Ruby, Python, PHP).
- scripttimeout -- sets the maximum runtime allowed for an embedded program (AppleScript, ShellScript, Perl, Ruby or Python).
- selectduplicatesdialog -- opens the standard Select Duplicates dialog.
- selectedformobjectsblueprintsheet -- opens a sheet to edit the blueprint of the currently selected objects.
- selectrecordsrelatedto -- selects records in the current database that are related to any record in another database.
- selectrelated -- selects information that matches the current record in a related database.
- selectzipdistancetool -- selects records near the current record, based on zip codes.
- sendaction -- sends an action message to the Cocoa responder chain.
- sendarrayemail -- sends a single e-mail to multiple recipients.
- sendbackward -- sends the selected form objects one layer towards the back.
- sendbulkemail -- sends a single e-mail to multiple recipients.
- sendemail -- sends an e-mail. It gives access to the maximum number of options available.
- sendoneemail -- sends a single e-mail to a single recipient.
- sendtoback -- sends the selected form objects to the back.
- setbannericon -- sets the icon on the right side of the toolbar banner.
- setbannermessage -- sets the text in the toolbar banner to an arbitrary message.
- setbannerprogressbar -- displays progress in the toolbar banner.
- setcookie -- set the value of a cookie to send back to the client..
- setdialogtrigger -- changes the value returned by the info("dialogtrigger") function.
- setformcustompreference -- sets the value of a form custom preference.
- setpreferencevalues -- creates and/or modifies a preference value.
- setreportcolumns -- allows a procedure to control the number of columns of a report, and the direction (across or down).
- settagdata -- changes the contents of a tag.
- settagparameter -- sets the value of a tag parameter in a list of tag parameters.
- settimechecklongtime -- sets the threshold for a slow task during a performance monitoring session.
- settrigger -- changes the value returned by the info("trigger") function.
- setxtagvalue -- changes the contents of a tag.
- setzlog -- turns instrumentation coverage on or off for a specific procedure (or all procedures within a database).
- shellscript -- executes a UNIX shell script.
- show -- resumes the output of text and graphics after it has been disabled and then forces Panorama to redisplay all windows in the current database.
- showlater -- defers the display of text and graphics until the procedure is finished.
- showline -- forces Panorama to redisplay the current record in all windows in the current database.
- showother -- forces Panorama to update some data on the screen.
- showpage -- forces Panorama to redisplay all windows in the current database.
- slidedata -- slides the columns at and to the right of the current column.
- sortdialog -- opens the standard *Sort* dialog.
- sortdown -- sorts the database by the current field. The database is sorted in descending order (high to low).
- sortdownwithin -- sorts the database by the current field, leaving any previous sorts intact. The database is sorted in descending order (high to low).
- sortup -- sorts the database by the current field. The database is sorted in ascending order (low to high).
- sortupwithin -- sorts the database by the current field, leaving any previous sorts intact. The database is sorted in ascending order (low to high).
- speak -- speaks a word or phrase.
- speakaddress -- buffers up a street address to be spoken later by the speaknow statement.
- speakcharacters -- buffers up one or more characters to be spoken later by the speaknow statement.
- speakcharactersslowly -- buffers up one or more characters to be spoken later by the speaknow statement. Instead of speaking words, each individual character is spoken separately and slowly.
- speakdate -- buffers up a date to be spoken later by the speaknow statement.
- speakdigitpairs -- buffers up one or more digit pairs to be spoken later by the speaknow statement.
- speakdigits -- buffers up one or more digits to be spoken later by the speaknow statement.
- speakdollars -- buffers up a dollar amount to be spoken later by the speaknow statement.
- speakdollarsandcents -- buffers up a dollar and cents amount to be spoken later by the speaknow statement.
- speakletters -- buffers up one or more characters to be spoken later by the speaknow statement. Letters will be spoken individually, as upper or lower case. Numbers will be spoken as individual digits.
- speaknow -- speaks any buffered speech.
- speakphonenumber -- buffers up a phone number to be spoken later by the speaknow statement.
- speakscript -- speaks a speech synthesis script created in the Database Options dialog.
- speakstate -- buffers up a US State to be spoken later by the speaknow statement.
- speakthisrecord -- speaks the current record in the database (using the default speech script).
- speakwords -- buffers up one or more words to be spoken later by the speaknow statement.
- speechrate -- changes the speech rate (words per minute).
- speechscripts -- returns a lists of speech scripts in a database.
- speechvoice -- changes the default speech voice.
- speechvolume -- changes the default speech volume.
- splitlines -- takes a chunk of text and splits it into two or more smaller chunks.
- splitmenutrigger -- splits info("trigger") into separate menu name and menu item variables.
- startdatabasechange -- adds undo support to a procedure.
- startstoprecorder -- starts or stops recording into the current procedure.
- starttimecheck -- starts a performance monitoring session.
- startupdatecheck -- starts background check for available Panorama update.
- stdout -- sends one or more characters to standard output.
- stopspeaking -- stops any talking that is currently happening.
- stoptimer -- stops and deletes a timer that was set up with the StartTimer statement.
- summarydatabaseselectoriginal -- selects original data corresponding to a cell in an exported summary table database.
- summaryselectoriginalformula -- returns the formula that will select the original data associated with a summary table row.
- summarytablepopup -- handles a click on a summary table text list.
- superalert -- will display a custom alert.
- superchoicedialog -- will display a dialog with a list of choices that can be selected. You can control the size of the alert, as well as several appearance options. If the alert has more than one button, info("dialogtrigger") will contain the name of the button that was pressed.
- supergetpassword -- will display a dialog with a text entry area for a password.
- supergettext -- will display a dialog with a text entry area.
- timecheck -- identifies an intermediate point in a performance monitoring session.
- timelimit -- specifies the maximum time a procedure can continue to run after this statement.
- total -- calculates totals and subtotals for the current field.
- updateballoonlocations -- does nothing.
- urltaskcancel -- aborts a download initiated with the urltask( function.
- urltaskstatus -- enables connection error checking in urltask( completion code.
- usebashprofile -- grabs the search path from the `.Bash_profile` file in the user's home folder, so that these paths will be used by scripting languages (*Ruby, Python*, etc.).
- wait -- pauses the program for a specified period of time.
- webselect -- selects data on web server using a formula.
- webshare -- perform record locking operations from a web publishing procedure.
- windowmenubar -- creates a custom menu bar or context menu for the current window (see Custom Menus).
- writedialogcode -- scans the current form, and writes the procedure needed to handle this form as a dialog.
- writepreference -- modifies a preference value.
- xcallbackurl -- performs an action in another application using the x-callback-url mechanism.
- zipinfo -- queries the web to obtain information about a zip code.
- zipinfoplus -- queries the web to obtain information about a zip code.
- zlog -- outputs a message to the instrumentation log (if instrumentation is enabled).
- zlogalways -- unconditionally outputs a message to the instrumentation log.
- zlogcoverage -- allows instrumentation coverage to be turned on or off within a procedure.
- zlogdictionary -- outputs a data dictionary to the instrumentation log (if instrumentation is enabled).
