arraynumericsort
INPUTARRAY
OUTPUTARRAY
SEPARATOR
The arraynumericsort statement sorts all the numeric elements of a text array in proper numeric order.
inputarray – the original text array containing numeric values.
outputarray – a copy of the original array sorted numerically.
separator – the separator character or characters.
The ArrayNumericSort statement sorts a text array that contains numeric values. See the arraynumericsort( function for details about the process of numerically sorting an array.
This code
local thenumbers
thenumbers="25.7;52.8;3.14;12.6"
arraynumericsort thenumbers, thenumbers,";"
will assign the value 3.14;12.6;25.7;52.8 to the variable thenumbers.
10.0UpdatedCarried over from Panorama 6.0, however, this is now a native function instead of being implemented as a custom statement. It's much faster and more robust than it was in Panorama 6.0. In addition, the arrayintegersort statement is now identical to the arraynumericsort statement. More than one character is now allowed for use as the separator parameter.
