seterror
VALUE
The seterror statement changes the error message returned by info(“error”).
value – is the text to be placed into the info(“error”) buffer.
This statement can be used in error handling code to change the text of the error message.
- catcherror( -- evaluates an expression, but suppresses any error generated by that expression.
- error( -- returns an error with the specified message.
- errortext( -- evaluates an expression, but returns only the error message generated (if any).
10.0 | No Change | Carried over from Panorama 6.0 (however, it was not documented before). |
