The makemergeformula statement makes a formula from a template.
This statement has three parameters:template – Text of template.
database – Database formula will be used in.
formula – Output formula.
This statement makes a formula from a template. Within the template you can place fields inside « and » characters and formulas inside { and } characters. Unlike the FormulaMerge statement, the formula is not evaluated.
local LetterFormula
makemergeformula |||Dear «Name», I will visit you in {sandwich("",City,", ")+State}|||,
"List",LetterFormula
The result, in LetterFormula, will look like this:
{Dear }+«Name»+{, I will visit you in }+sandwich("",City,", ")+State+{}
