deletefield
The deletefield statement deletes the current field from the database.
This statement removes the currently active field from the database and all data contained in that field without any prior warning. This statement will delete any type of field, however Panorama will not allow you to delete a field if it is the only one in the database.
This simple example will delete the field called Temp.
field Temp
deletefield
This example ask you if you wish to delete the current field and only does so if you click Yes.
alertnoyes "Do you really want to delete the field: "+info("fieldname")+"?"
if info("dialogtrigger") contains "yes"
deletefield
- automaticfieldname( -- returns an available field name.
- Field Blueprint Dialog -- examining and modifying the raw specification of a field.
- fieldalignment( -- returns the alignment of a database field.
- fieldformula( -- returns the formula associated with a database field.
- fieldnumber( -- returns the number of a database field (starting with 1).
- fieldpattern( -- returns the output pattern associated with a database field.
- fieldtypes( -- returns a carriage return delimited array with a list of the fields and field data types.
- fieldwidth( -- returns the width (in the data sheet) of a database field.
- hiddenfields( -- returns a list of hidden fields in the curent data sheet window
- visiblefieldnumbers( -- returns a data array of visible fields (by number) in the data sheet.
- visiblefields( -- returns a list of visible fields in the data sheet.
