makefolder
PATH
The makefolder statement creates a new folder, and if necessary, also creates any enclosing folders needed to create the specified new folder.
path – is a path and folder name of the new folder to be created (see Files and Folders for more information about file paths).
This statement creates a new folder, and if necessary, also creates any enclosing folders needed to create the specified new folder. If a folder with that name already exists, the statement will do nothing.
This example creates a folder named Cambria. If necessary, it also creates the Dropbox, Projects, and 2014 folders.
makefolder "~/Dropbox/Projects/2014/Cambria"
Legacy MakeNewFolderStatement
In previous versions of Panorama (version 6 and before) the makefolder statement would not create any necessary enclosing folders, and a separate makenewfolder statement was included with that capability. For compatibility with existing databases the makenewfolder statement will work (it is an alias for the makefolder statement.)
10.0 | Updated | Carried over from Panorama 6.0 but automatically creates any enlosing folders necessary to create the target folder. For compatibility with existing databases the makenewfolder statement is now an alias of this statement. |
