executesudounix
SHELLCOMMAND
PASSWORD
RESULT
TIMEOUT
The executesudounix statement executes a UNIX shell command using sudo (root) privileges.
shellcommand – Exact text of shell command.
password – Password (if empty then will prompt for password).
result – Output of shell command.
timeout – Timeout in seconds (default is 60 if not supplied).
This statement executes a UNIX shell command using SUDO (root) privileges.
executeunix {chown myname afile},“”,ux
Note: This statement has been superceded by the shellscript statement and shellscript( function.
