scaleselectedobjects
SCALE
The scaleselectedobjects statement scale the selected objects by a specified factor.
scale – scale factor. If this ends with %, the factor is a percentage, for example “50%”. Otherwise, this is a multiplication factor, for example “0.5”. If the value is empty, the user will be prompted with a dialog.
This statement will scale the selected objects by a specified factor.
scaleselectedobjects "50%"
If the factor is empty, the user will be prompted to enter the scale factor in a dialog.
scaleselectedobjects ""
Note: This statement is used internally by Panorama for the Scale submenu in the Objects menu and in the graphics mode Context menu (right click).
| 10.2.2 | New | New in this version. |
