alertyesnocancel
TEXT
The alertyesnocancel statement displays a modal alert window with a message and three buttons: Yes, No and Cancel.
This statement displays a modal alert window with a message and three buttons: Yes, No and Cancel (Yes is the default.) Afterwards, the name of the button that was clicked can be accessed with the info(“dialogtrigger”) function.
alertyesnocancel "Do you want to continue?"
if info("dialogtrigger") = "Cancel"
stop
if info("dialogtrigger") = "No"
Status = "Hold"
else
