renderwebform
FORM
RECORD
OUTPUT
VARIABLES
The renderwebform statement renders a Panorama web form into HTML, merging data into the template as necessary.
form – name of form to render (in the current database).
record – information for selecting record to render, see the WebURLSelect statement.
output – field or variable to place final result into
variables – carriage return separated list of variables to be merged into text editor cells, radio buttons, pop-up menus, etc.
This statement renders a Panorama web form into HTML, merging data into the template as necessary.
renderwebform "Invoice","NUM-2654",cgiHTML
| 10.2 | No Change | Carried over from Panorama 6.0. |
