info("error")
The info(“error”) function returns the most recent error message.
The info(“error”) function can be used after an error has been caught. (Errors can be caught by if error, by try catch, or by onerror. See Error Handling for more information about error trapping.) The function returns the error message that would have been displayed if the error had not been trapped.
- catcherror( -- evaluates an expression, but suppresses any error generated by that expression.
- error( -- returns an error with the specified message.
- errortext( -- evaluates an expression, but returns only the error message generated (if any).
- quit -- quits Panorama.
