arrayrandomize
OLDARRAY
NEWARRAY
SEP
The arrayrandomize statement reorders an array in random order.
oldarray – The original array.
newarray – The randomized output array.
sep – The separator character used in this array.
This statement reorders an array in random order. This example will rearrange the words in this sentence in random order.
local jabber
arrayrandomize "Now is the time for action",jabber," "
message jabber
