saveoneprocedure
DATABASE
PROCEDURE
DICTIONARY
The saveoneprocedure statement saves a specific procedure in the specified database into a dictionary.
database – Name of the database, or “” for current database.
procedure – Name of the procedure, or “” for current procedure.
dictionary – Field or variable to store result in.
This statement saves a specific procedure in the specified database into a dictionary.
SaveOneProcedure "",info("formname"),myProcedureDict
Later, you can load the dictionary back into a database with the LoadAllProcedures statement.
