insertbelow
The insertbelow statement inserts a new record below the current record.
This statement adds a new record below the current record.
This simple example inserts twelve new records into the middle of the current database.
loop
insertbelow
until 12
Note: This statement inserts a record without changing the current column. If you want to insert a record and move to the first column in the database, use the InsertBelowCarriageReturn statement.
| 10.0 | Updated | Carried over from Panorama 6.0, but no longer moves to the first column of the database (use the InsertBelowCarriageReturn statement if that is what you want. |
