showallfields
The showallfields statement makes every field in the data sheet visible.
This statement makes all fields visible in the current data sheet. Any hidden fields will be revealed, up to the maximum number of visible fields, as specified in PanoramaX preferences (see Limiting the Maximum Number of Data Sheet Columns.
- hiddenfields( -- returns a list of hidden fields in the curent data sheet window
