buildwizardmenus
The buildwizardmenus statement scans the wizard folder to build the Wizard menu and submenus.
This statement scans the wizard folder to build the Wizard menu and submenus.
buildwizardmenu
This statement is used by Panorama when it starts up. You would normally never need to use this statement unless you added or removed wizards.
