installpanoramacgi
OPTIONS
The installpanoramacgi statement installs Panoramax.cgi for use with external web server.
options – dictionary of options, see below.
This statement installs Panoramax.cgi for use with an external web server. There is one parameter, a dictionary that customizes the operation. If all the options are omitted, the statement will install the CGI included inside the Panorama application into the default location for the Apache web server. However, at least one option is required, the system password. This is the necessary so that Panorama can get permission to make the installation.
installpanoramacgi initializedictionary(
"PASSWORD","1234"
The available options are:
- PASSWORD - The administrator password for the computer.
- FILENAME - The installed filename of the CGI. If this is omitted the filename will be
panoramax.cgi
- CGIPATH - The location where the CGI will be installed. If this option is omitted the CGI will be installed to
/Library/WebServer/CGI-Executables
- SOURCECGI - The location and filename of the CGI to be installed. If this is omitted the CGI included inside the Panorama application will be installed.
Note: This statement is normally used only by Panorama itself. The primary method for installing the CGI is to use the Apache panel of the Preferences window.
- Web Cookies -- web cookies.
