saveopenprocedures
DATABASE
DICTIONARY
The saveopenprocedures statement saves all the open procedures in the specified database into a dictionary.
database – Name of the database, or “” for current database.
dictionary – Field or variable to store result in.
This statement saves all the open procedures in the specified database into a dictionary.
SaveOpenProcedures "",myProcedureDict
Later, you can load the dictionaries back into a database with the LoadAllProcedures statement.
