gettaglocation
PAGE
PREFIX
SUFFIX
START
LENGTH
The gettaglocation statement locates the first matching tag within some text.
This statement has five parameters:
page – text that may contain tag.
prefix – opening tag.
suffix – closing tag.
start – field or variable that will contain the position of start of tag (or 0 if tag not found).
length – field or variable that will contain the position of length of tag (or 0 if tag not found)
This statement locates the first matching tag within some text. This example assumes the current database has a field named Page that contains HTML.
local tableStart,tableLen
gettaglocation Page,"<table","</table>",tableStart,tableLen
If the Page field contains one or more tables, the tableStart and tableLen variables will be set with the position and length of the first table in the text.
- gettaglocations -- locates all matching tags within some text.
- settagdata -- changes the contents of a tag.
- setxtagvalue -- changes the contents of a tag.
- tagcount( -- counts the number of times a specified tag (usually an HTML tag) appears in the text. See Tag Parsing for more information on HTML tags.
- tagdata( -- extracts the body of the specified tag (usually an HTML tag) in the text. See Tag Parsing for more information on HTML tags.
- tagend( -- returns the ending position of the specified tag (usually an HTML tag) in the text.
- tagnumber( -- checks to see if a specified position is inside of a tag (usually an HTML tag).
- tagparameter( -- extracts the value of a tag parameter embedded in some text, where the tag parameter takes the form *name=value*.
- tagstart( -- returns the starting position of the specified tag (usually an HTML tag) in the text.
- tagstrip( -- removes tags (usually HTML tags) from within a piece of text.
