hidethesefields
FIELDS
The hidethesefields statement hides specific fields in the data sheet, making all others visible.
fields – is a carriage return delimited list of fields to hide.
This statement hides specific fields in the data sheet, making all others visible.
This example will temporarily hide sensitive fields in a personnel database.
hidethesefields commatocr("Salary,Birthday")
- hiddenfields( -- returns a list of hidden fields in the curent data sheet window
