arrayunpropagate
INPUT
TEXT
SEPARATOR
The arrayunpropagate statement scans an array from top to bottom, removing duplicate values in a row.
input – Original array.
text – Modified array.
separator – Separator character.
This statement scans an array from top to bottom. If it finds two or more duplicate values in a row, it blanks out all but the first. This is similar to the Unpropagate statement, but for an array instead of a database field.
This example blanks out consecutive duplicates from an array.
arrayunpropagate classes,classes,cr()
The arrayunpropagate does not sort the array before hand so you may want to use arraysort( before using arrayunpropagate as in this example.
arrayunpropagate arraysort(classes,cr()),classes,cr()
