selectnoobjects
The selectnoobjects statement unselects all the graphic objects in the current form.
This statement tells Panorama to unselect all the graphic objects within a form. Usually this is done to “clean up” after a procedure has selected graphic objects.
This example will reduce the brightness of every object in the form by 20%. When it is done it politely unselects the graphic objects.
selectallobjects
changeobjects "color",hsb(
hue( objectinfo("color") ),
saturation( objectinfo("color") ),
0.8*brightness( objectinfo("color") ))
selectnoobjects
- info("activeobject") -- returns the name of the currently active text editor or word processor object (if any).
- info("scrollpoint") -- returns the distance the current form is scrolled horizontally and vertically.
- objectinfo( -- returns information about a graphic object: its location, size, color, font, etc.
- objectinfoarray( -- builds a text array of form object properties
- Web Browser Programming -- programming a Web Browser Object (including JavaScript).
