enterprisecall
DATABASE
PROCEDURE
The enterprisecall statement calls a procedure in a server database, opening and closing the database if necessary.
database – name of the DATABASE to open. This must be a designated server file.
procedure – name of the procedure to call. If this parameter is empty (""), the database will be opened without calling any procedure.
This statement calls a procedure in a server database, opening and closing the database if necessary. The database will be made active with a secret window.
enterprisecall "WebContacts","PhoneList"
10.2UpdatedCarried over from Panorama 6.0, uses new protocol.
