cloneobjects
PROPERTY
VALUE
The cloneobjects statement duplicates objects in a form (with modifications).
property – the object property (color, font, etc.) to modify. See Modifiable Object Properties for descriptions of the different properties that can be modified. Standard properties can be specified in either upper or lower case, but native properties are case sensitive.
value – The new value for this property. Note: Instead of specifying the property names and values as separate parameters, you can specify multiple properties with a dictionary. See the main text below for more information.
This statement clones selected objects in a form. Usually a procedure will use the SelectObjects statement to select the objects before cloning them. This example assumes that the current form has a row of objects inside an object named RowArea (see Object Names). The procedure copies the objects, making a second row just below the existing row.
local rowRectangle
rowRectangle = objectinfo("rectangle","RowArea")
// select objects in row
selectobjects unionrectangle(objectinfo("rectangle"),rowRectangle)=rowRectangle
cloneobjects "rectangle",rectangleoffset(objectinfo("rectangle"),rheight(rowRectangle),0)
You can specify multiple property/value pairs in a single cloneobjects statement, like this:
cloneobjects property1,value1,property2,value2,property3,value3
Here’s a more complicated example. Suppose the current form contains a row of text editor objects for editing line item fields, perhaps Qty1, Product1, Price1 and Total1. This procedure will create a second row 2 points below the current row, with the field names adjusted to Qty2, Product2, Price2 and Total2.
local rowRectangle,rowNumber
rowNumber = 1
selectobjects objectinfo("fieldname") endswith str(rowNumber)
rowrectangle = objectinfo("boundary")
cloneobjects "rectangle",rectangleoffset(objectinfo("rectangle"),rheight(rowRectangle)+2,0),
"fieldname",replace(objecinfo("fieldname"),str(rowNumber),str(rowNumber)+1)
With slight adjustments this procedure could be modified to make rows 3, 4, 5, etc. (Further modifications would be required if you wanted to go past 9, perhaps changing the endswith operator to a regular expression (see regexmatch), like this:
selectobjects objectinfo("fieldname") regexmatch "[a-zA-Z]+"+str(rowNumber)+"$"
You can also specify the properties with a dictionary, as shown below:
rowNumber = 1
cloneobjects initializedictionary(
"fieldname",replace(objectinfo("fieldname"),str(rowNumber),str(rowNumber)+1))
The two previous example perform the exact same modification to the selected objects. The advantage of using a dictionary is that you can prepare it in advance in a variable, and then use it over and over again (possibly adjusting it with the changedictionaryvalues( function).
- info("activeobject") -- returns the name of the currently active text editor or word processor object (if any).
- info("scrollpoint") -- returns the distance the current form is scrolled horizontally and vertically.
- objectinfo( -- returns information about a graphic object: its location, size, color, font, etc.
- objectinfoarray( -- builds a text array of form object properties
- Web Browser Programming -- programming a Web Browser Object (including JavaScript).
10.0 | Updated | New in this version. |
