autoallfieldwidths
The autoallfieldwidths statement automatically sets the width of all fields based on the data in each field.
This statement automatically sets the width of all fields based on the field name width as well as the actual data in each field. This statement should only be used in a data sheet view. Note: This statement uses an approximation to calculate the width – it may not exactly fit the data.
- automaticfieldname( -- returns an available field name.
- Field Blueprint Dialog -- examining and modifying the raw specification of a field.
- fieldalignment( -- returns the alignment of a database field.
- fieldformula( -- returns the formula associated with a database field.
- fieldnumber( -- returns the number of a database field (starting with 1).
- fieldpattern( -- returns the output pattern associated with a database field.
- fieldtypes( -- returns a carriage return delimited array with a list of the fields and field data types.
- fieldwidth( -- returns the width (in the data sheet) of a database field.
- hiddenfields( -- returns a list of hidden fields in the curent data sheet window
- visiblefieldnumbers( -- returns a data array of visible fields (by number) in the data sheet.
- visiblefields( -- returns a list of visible fields in the data sheet.
10.0 | Updated | Carried over from Panorama 6.0. |
