makesecret
The makesecret statement makes the current database disappear, while leaving it open in memory.
The makesecret statement makes the current database disappear. All of the windows for this database will be closed. However, the database is still in memory, so the database can still be used for lookups, etc.
The procedure below makes the Price List database disappear, but remain open (this example assumes that the Price List data sheet is currently visible).
window "Price List"
makesecret
Even though the Price List database is now invisible, you can still access information in the database.
myPrice=lookup("Price List",Description,Item,Price,0,0)
To make the windows of a database visible again, use the opensavedwindows statement.
setactivedatabase "Price List"
opensavedwindows
To modify information in a hidden database you must temporarily create a secret window. This can be done with the window statement. This example adjusts the quantity of an item in an invisible inventory file.
local wasWindow
wasWindow=info("windowname")
window "Inventory:Secret"
find Description=fieldvalue("Invoice",InvoiceItem)
OnHandQty=OnHandQty-fieldvalue("Invoice",InvoiceQt
window wasWindow
Note: A simpler method to do this is to use the Post or PostAdjust statements:
