importdictprocedures
SOURCETEXT
DICTIONARY
The importdictprocedures statement converts source code exported by the ExportAllProcedures statement into a dictionary.
sourcetext – Source code that was exported with the ExportAllProcedures statement.
dictionary – Field or variable to store result in.
This statement converts source code exported by the ExportAllProcedures statement into a dictionary. This dictionary can be used with the LoadAllProcedures statement.
This example transfers all of the procedures from the current database into some other database.
global psave
exportallprocedures "",psave
window "Some Other Database"
local psDictionary
importdictprocedures psave,psDictionary
loadallprocedures psDictionary
