addremotehost
URL
HOSTNAME
The addremotehost statement makes a remote host available to this computer.
url – is the url of the host to be added to the list of hosts available to this computer.
hostname – is a field or variable in which the name of the connected host will be placed. This parameter is optional, if you don’t care what the name of the host server is, you can omit it.
This statement makes a remote host available to this computer. For example
addremotehost "http://myremotehost.com"
If the remote host is not on port 80, the port number must be included in the URL, like this:
addremotehost "http://myremotehost.com:8080"
Once the remote host has been added, you’ll see it listed in the Server Administration Wizard.
- Web Cookies -- web cookies.
