webfontsubstitutes
DATABASE
The webfontsubstitutes statement generates an array of standard font substitutions for web browsers.
database – field or variable to receive the list of font substitutions.
This statement generates an array of standard font substitutions for web browsers (for use with MakeFormWebTemplate). Each line is a comma separated list of substitutions for an individual font, for example
"Arial","Helvetica",sans-serif
This example loads the list of font substitutions into a local variable.
local fontTable
webfontsubstitutes fontTable
10.2 | No Change | Carried over from Panorama 6.0. |
