databaseoptionsdialog
The databaseoptionsdialog statement opens the standard Database Options dialog.
This statement opens Panorama’s standard Database Options dialog so that settings for the current database can be customized.
- copycell -- copies the contents of the current field onto the clipboard,
replacing anything previously on the clipboard.
- formulacalc -- allows you to evaluate a formula that you were not able to
code into the procedure when it was being written.
