removedetail
LEVEL
The removedetail statement removes data records from the current database, leaving only summary records. It can also delete low level summary records, leaving only higher levels.
level – specifies the minimum summary level that will not be removed. In other words, if you want to remove only data records this value should be zero. If you want to remove data records and the first level of summary this value should be 1, etc. This value may be between 0 (data records) and 6 (highest level summary), however, it should not be more than one less than the highest summary level in the database. (You can determine the highest summary level available using the dbinfo(“maxsummarylevel”) function.)
This example calculates summaries for each company, then saves those summaries in a separate database. The Company Totals database will not have any of the original data, only the summary information (which will have been converted into data records for possible further processing.)
field Company
group
field Amount
total
removedetail 0
saveas "Company Totals"
Error Messages
RemoveDetail statement cannot remove all data from the database – This message will be generated if the level parameter is equal to or above the maximum summary level currently in the database.
10.0UpdatedCarried over from Panorama 6.0, but no longer supports the dialog option.
