alertsavecancel
TEXT
The alertsavecancel statement displays a modal alert window with a message and two buttons: Save and Cancel.
This statement displays a modal alert window with a message and two buttons: Save and Cancel. (Save is the default.) Afterwards, the name of the button that was clicked can be accessed with the info(“dialogtrigger”) function.
alertsavecancel "Do you want to save?"
if info("dialogtrigger") = "Cancel"
stop
