alertrevertcancel
TEXT
The alertrevertcancel statement displays a modal alert window with a message and two buttons: Revert and Cancel.
This statement displays a modal alert window with a message and two buttons: Revert and Cancel. (Revert is the default.) Afterwards, the name of the button that was clicked can be accessed with the info(“dialogtrigger”) function.
alertrevertcancel "Do you want to revert?"
if info("dialogtrigger") = "Cancel"
stop
