cell
VALUE
The cell statement enters a value into the currently active field (i.e. cell).
value – The value to enter in the field.
This statement enters a value into the currently active field (i.e. cell), and runs any calculations associated with that field.
This example increases the price by 30%:
Field "Price"
cell «»*1.3
Note: This is equivalent to:
Price = Price*1.3
runfieldcalculations
- automaticfieldname( -- returns an available field name.
- Field Blueprint Dialog -- examining and modifying the raw specification of a field.
- fieldalignment( -- returns the alignment of a database field.
- fieldformula( -- returns the formula associated with a database field.
- fieldnumber( -- returns the number of a database field (starting with 1).
- fieldpattern( -- returns the output pattern associated with a database field.
- fieldtypes( -- returns a carriage return delimited array with a list of the fields and field data types.
- fieldwidth( -- returns the width (in the data sheet) of a database field.
- hiddenfields( -- returns a list of hidden fields in the curent data sheet window
- visiblefieldnumbers( -- returns a data array of visible fields (by number) in the data sheet.
- visiblefields( -- returns a list of visible fields in the data sheet.
10.0 | Updated | Carried over from Panorama 6.0. |
