bigmessage
MESSAGE
The bigmessage statement displays a message alert.
message – message that appears in the alert.
This statement displays a message alert. In previous versions of Panorama this alert would be larger than the normal message alert, but now the regular message statement will automatically expand to accomodate any amount of text, so this statement is now redundant. It is still included for compatibility with existing databases that are already using it.
Here is an example of how this statement is used:
bigmessage "You could put a lot of text here!"
- activegrid -- manages the operation of a grid that controls a series of options.
- analyzedialog -- opens the standard Analyze dialog.
- closeallasyncprogresswindows -- closes any asynchronous progress windows.
- columnstatsdialog -- opens the standard Column Stats dialog.
- customdialog -- customizes the appearance of the gettext and getscrap dialogs.
- editfavoritesdialog -- handles the Favorites button in a dialog.
- favoritedatabasedialog -- opens the standard Favorite Databases dialog.
- favoritesbutton -- handles the *Favorites* button in a dialog.
- getscrap -- will display a dialog with a text entry area. The entered text is placed in the clipboard.
- getscrapok -- will display a dialog with a text entry area. The entered text is placed in the clipboard.
- gettextdialog -- displays a configurable modal dialog that asks the user to enter an item of text.
- importdatabasedialog -- opens the standard Import Database dialog.
- joindialog -- opens the standard Join Database dialog.
- morphalldialog -- opens the standard MorphAll dialog.
- morphdialog -- opens the standard Morph dialog.
- popupsharingmenu -- pops up a menu for the toolbar sharing icon.
- rundialog -- uses a form as a template to display a modal dialog window. The statement supervises the operation of the dialog until it is closed.
- rundialogmenus -- enables custom menus in a modal dialog.
- selectduplicatesdialog -- opens the standard Select Duplicates dialog.
- sortdialog -- opens the standard *Sort* dialog.
- supergetpassword -- will display a dialog with a text entry area for a password.
- supergettext -- will display a dialog with a text entry area.
10.0 | No Change | Carried over from Panorama 6.0, but is now redundant. |
