datafocus
The datafocus statement makes sure that Panorama is focused on data, not on a property panel.
This statement makes sure that Panorama is focused on data, not on a property panel. For example, if a user is editing the name of a field using the property inspector, this statement terminates the editing so that Panorama is ready to perform other database operations.
Panorama uses this statement internally when inserting and deleting fields.
datafocus
startdatabasechange {FIELDCONFIGURATION},{Delete Field}
deletefield
