formulacalc
RESULT
FORMULA
The formulacalc statement allows you to evaluate a formula that you were not able to
code into the procedure when it was being written.
result – must be the name of a field or a variable where you wish the result of the formula to be placed. The formula’s resulting value must match the type and format (if any) of result or an error alert dialog will be displayed. If a field is specified it must be in the current database.
formula – is the formula to be calculated. Unlike an assignment statement, the formula itself is calculated by another formula, allowing you to change the formula on the fly. If the formula doesn’t need to be changed you must enclose it in quotes, but you can also store the formula in a variable or even calculate the formula with another formula.
This statement calculates the result of a formula. This statement allows you to change the formula on the fly.
This simple example allows the user to enter a calculation to be performed.
local myFormula,myResult
gettext "Enter Formula:",myFormula
formulacalc myResult,myFormula
message myResult
- Arithmetic Formulas -- mathematical operators and functions.
- Characters and Unicode Values -- working with individual characters of text.
- Constants -- values embedded into a formula.
- Date Arithmetic Formulas -- performing calculations on dates, and converting between dates and text.
- Formula Workshop -- formula workshop wizard for testing and experimenting with formulas.
- formulafields( -- returns a list of fields used in a formula.
- formulaidentfiers( -- returns a list of identifiers (fields and variables) used in a formula.
- Formulas -- basics of formulas: components and grammar.
- formulavariables( -- returns a list of variables used in a formula.
- Functions -- index of all functions available for use in Panorama formulas.
- Linking with Another Database -- techniques for relating multiple database files so that they work together.
- Non Decimal Numbers -- working with numbers in alternative (non-decimal) bases, including binary, octal and hexadecimal.
- Numbers -- Working with numeric values in a formula, and converting between numbers and text.
- Operators -- index of all operators available for use in Panorama formulas.
- Quotes -- text constants embedded into a formula
- Recompiling Code -- recompiling code & formulas
- Statements -- index of all statements available for use in Panorama procedures.
- SuperDates -- date and time combined into a single value.
- Tag Parsing -- Panorama functions for working with text that contains data delimited by tags, including HTML.
- Text Formulas -- manipulating text with a formula (concatenation, extraction, rearranging, etc.)
- Time Arithmetic Formulas -- performing calculations on times, and converting between times and text.
- True/False Formulas -- logical boolean calculations.
- Using Fields in a Formula -- accessing database fields within a formula.
- Values -- the raw material that formulas work with -- numbers and text.
- Variables -- storing and retrieving individual items of data, not part of a database.
