alertokcancel
TEXT
The alertokcancel statement displays a modal alert window with a message and two buttons: Ok and Cancel.
This statement displays a modal alert window with a message and two buttons: Ok and Cancel. (Ok is the default.) Afterwards, the name of the button that was clicked can be accessed with the info(“dialogtrigger”) function.
alertokcancel "Do you want to continue?"
if info("dialogtrigger") = "Cancel"
stop
