setglobal
DESTINATION
FORMULA
The setglobal statement sets a value into a global variable. The name of the global variable is calculated on the fly.
destination – is a formula that calculates the name of the global variable that you want to modify.
formula – calculates the value that will be placed into the destination global variable.
This statement sets a value into a global variable. The name of the global variable is calculated on the fly.
setglobal datepattern( today(),"DayOfWeek"),DepartureTime
Here is the same procedure rewritten without using the setglobal statement. This illustrates the power of the setglobal statement, which in this case is doing the same work as 17 statements.
global Sunday,Monday,Tuesday,Wednesday,Thursday,Friday,Saturday
local dayName
dayName=datepattern( today(),"DayOfWeek")
case dayName="Sunday"
Sunday=DepartureTime
case dayName="Monday"
Monday=DepartureTime
case dayName="Tuesday"
Tuesday=DepartureTime
case dayName="Wednesday"
Wednesday=DepartureTime
case dayName="Thursday"
Thursday=DepartureTime
case dayName="Friday"
Friday=DepartureTime
case dayName="Saturday"
Saturday=DepartureTime
endcase
