disableabort
The disableabort statement prevents loops from being stopped early by pressing SHIFT-COMMAND-ESCAPE or by exceeding the maximum allowed loop time.
This statement prevents loops from being stopped early by pressing SHIFT-COMMAND-ESCAPE or by exceeding the maximum allowed loop time. This statement can be used to make sure that a sequence of steps is always completed – even if the user presses SHIFT-COMMAND-ESCAPE or if there is a maximum loop time preference set. To learn more, see Preventing Endless Loops.
When using the disableabort statement you must be careful, especially when using loops. The procedure below will hang Panorama because tag=“” will never be true. The only way to stop the loop is to force quit Panorama (Command-Shift-Option-Escape).
disableabort
let i=1
loop
let tag="<"+array(Text,i,cr())+">"
stoploopif tag=""
i=i+1
while forever
enableabort
While this example may look silly, it is easy to create an endless loop without realizing it.
- goto -- allows a procedure to arbitrarily jump from one spot to another
within the procedure.
- quit -- quits Panorama.
- setparameter -- is used to transfer data from a subroutine back to the main
10.2 | Updated | Carried over from Panorama 6.0, but with updated behavior. |
