summarylevel
LEVEL
The summarylevel statement changes the summary level of the current line.
level – is a number that specifies the new summary level of the record. This value may be between 0 (data record) and 7 (highest level summary).
This statement will arbitrarily change the summary level of the current line. This is usually not a very useful thing to do, and we don’t recommend doing it. It is generally better to let summary records be manipulated by the Groupup, RemoveSummaries, and RemoveDetail statements. Note: A procedure can find out the summary level of the current record with the info(“summary”) function.
This example increases the summary level of the current record. If the current record is a data record, it becomes a level 1 summary, if it is a level 1 summary it becomes level 2. (Don’t ask why you would do this, it’s just an example!)
if info("summary") < 7
    summarylevel 1+info("summary")
