- arraymenuitems( -- The arraymenuitems( function converts a carriage return delimited array into a series of menu items.
- checkedarraymenuitems( -- The checkedarraymenuitems( function converts a carriage return delimited array into a series of menu items, some of which may be checked.
- checkedmenuitem( -- The checkedmenuitem( function creates a single menu item with an optional checkmark.
- dbconstructormenu( -- The dbconstructormenu( function used internally by ProVUE
- filemenubar -- The filemenubar statement creates a custom menu bar or context menu for the current database (see Custom Menus).
- globalmenubar -- The globalmenubar statement creates a custom menu bar or context menu for all windows (intended only for internal use by ProVUE Development).
- info("menuidentifier") -- The info("menuidentifier") function returns the identifier of the most recently chosen menu item (if any).
- LMSL -- is the specification language for Live Menus.
- menu( -- The menu( function creates a menu (see Custom Menus).
- menuitem( -- The menuitem( function creates a single menu item (see Custom Menus).
- menuitems( -- The menuitems( function converts a semicolon separated array into a live menu specification.
- menuseparator( -- The menuseparator( function generates a menu item separator
- noactionmenu( -- The noactionmenu( function suppresses the Action menu.
- noinstrumentationmenu( -- The noinstrumentationmenu( function supresses the Instrumentation menu.
- nowizardmenu( -- The nowizardmenu( function suppresses the Wizards menu.
- popup -- The popup statement makes a pop-up menu appear anywhere on the screen.
- popupatmouse -- The popupatmouse statement displays a pop-up menu at the current mouse location.
- popupbelowbutton -- The popupbelowbutton statement displays a pop-up menu in response to clicking on a button.
- popupbutton -- The popupbutton statement displays a pop-up menu in response to clicking on a button.
- popupbynumber -- The popupbynumber statement makes a pop-up menu appear anywhere on the screen.
- popupclick -- The popupclick statement displays a pop-up menu at the current mouse location.
- popupdoublefieldchoices -- The popupdoublefieldchoices statement displays a pop-up menu listing values in a specified field, with submenus containing values from a second field.
- popupfieldchoices -- The popupfieldchoices statement displays a pop-up menu listing values in a specified field.
- shortstandardviewmenu( -- The shortstandardviewmenu( function generates a Live Menu specification for a truncated version of Panorama’s standard View menu.
- standardactionmenu( -- The standardactionmenu( function generates a Custom Menu specification for Panorama's standard Action menu.
- standardclassicsetupmenu( -- The standardclassicsetupmenu( function generates a customizable Custom Menu specification for Panorama's classic Setup menu.
- standardconstructgraphicsmenu( -- The standardconstructgraphicsmenu( function generates a Custom Menu specification for Panorama’s standard Construct menu (in Graphics Mode).
- standardeditmenu( -- The standardeditmenu( function generates a customizable Custom Menu specification for Panorama's standard Edit menu.
- standardfieldsmenu( -- The standardfieldsmenu( function generates a customizable Custom Menu specification for Panorama's standard Fields menu.
- standardfilemenu( -- The standardfilemenu( function generates a customizable Custom Menu specification for Panorama's standard File menu.
- standardhelpmenu( -- The standardhelpmenu( function generates a customizable Custom Menu specification for Panorama's standard Help menu.
- standardinstrumentationmenu( -- The standardinstrumentationmenu( function generates a Custom Menu specification for Panorama’s standard Instrumentation menu.
- standardpanoramamenu( -- The standardpanoramamenu( function generates a Custom Menu specification for Panorama's standard Panorama menu.
- standardrecordsmenu( -- The standardrecordsmenu( function generates a customizable Custom Menu specification for Panorama's standard Records menu.
- standardsearchmenu( -- The standardsearchmenu( function generates a customizable Custom Menu specification for Panorama's standard Search menu.
- standardsetupmenu( -- The standardsetupmenu( function generates a customizable Custom Menu specification for Panorama's standard Setup menu.
- standardsortmenu( -- The standardsortmenu( function generates a customizable Custom Menu specification for Panorama's standard Sort menu.
- standardtextmenu( -- The standardtextmenu( function generates a customizable Custom Menu specification for Panorama's standard Text menu.
- standardviewmenu( -- The standardviewmenu( function generates a Custom Menu specification for Panorama's standard View menu.
- standardwindowmenu( -- The standardwindowmenu( function generates a customizable Custom Menu specification for Panorama's standard Window menu.
- standardwizardsmenu( -- The standardwizardsmenu( function generates a Custom Menu specification for Panorama's standard Wizards menu.
- submenu( -- The submenu( function creates a submenu (see Custom Menus).
- windowmenubar -- The windowmenubar statement creates a custom menu bar or context menu for the current window (see Custom Menus).
