formcolor
COLOR
The formcolor statement changes the background color of the current form.
color – is the new background color (see Colors).
This statement changes the background color of the current form. The default background color is white, but you can change it to any color with this statement. (The background color can also be changed manually by going into Graphics Mode and using the Property Inspector.) A procedure can find out what the current background form color is with the info(“formcolor”) function.
The example sets the background color to light gray.
formcolor rgb(56000,56000,56000)
Note: If you want to change the background of another form (not the current form) use the setformoptions statement.
