try
The try statement works with catch and endcatch to trap errors in a sequence of statements.
See Error Handling for details on using this statement.
Error Messages
TRY without CATCH or ENDCATCH – Each TRY statement must be paired with corresponding CATCH and ENDCATCH statements.
- quit -- quits Panorama.
