addlines
FIELD
START
END
BUMP
COPIES
The addlines statement adds a specified number of records to the end of a database.
This statement has five parameters:
field – the name of the field you wish to increment as the new records are added to the database. This parameter must either be a numeric integer field, date type field, or it may be a variable if you don’t want to store the incrementing values in the database.
start – is the beginning sequence number or date value.
end – is the ending sequence number or date value.
bump – is the increment value for your sequence. The bump value must be a positive integer if the field is an integer field. For a date field the bump value may also be one of the following:
- “Month” – for month (can also abbreviate as M)
- “Year” – for year (can also abbreviate as Y)
- 1 – for day
- 7 – for week
If the bump parameter is omitted, it is assumed to be 1.
copies – is the number of records generated for each sequence number. If this parameter is omitted, it is assumed to be 1.
This statement adds a predetermined number of records to the end of any database. The new records may be sequenced with incrementing integer or date values in a specified field.
This example shows how a procedure can add 100 records to a database and sequence those new records from 1200 to 1299 in a numeric integer field called CheckNum.
addlines CheckNum,1200,1299
This example shows how a procedure can add 31 records to a database and sequence those new records from October 1 to October 31 in a date field called EntryDate (Panorama will assume the year based on the computers system date).
addlines EntryDate,date("oct 1"),date("oct 31")
This procedure will add one record for each month to a database and sequence those new records from a start date to an end date that the user specifies. The date field sequenced is called Date. This time the bump value is “Month” , indicating that the value should be incremented by one month for each record.
local Start,End
gettext "Enter Start date, ex: 1/1/95",Start
Start = date( Start) /* converts to a date value */
gettext "Enter End date, ex: 12/1/95",End
End = date( End) /* convert to a date value */
addlines Date,Start,End,"Month"
This example adds 20 records to a database and sequences those new records from 1 to 10 in a field called In/Out, but makes two records for each sequence value by setting copies to 2. Notice also that the end value is a simple formula 1+9. The resulting sequence will be 11223344 …
addlines «In/Out»,1,1+9,1,2
This example adds 10 records to a database, however no field will be sequenced because a variable is used as the first parameter.
local Useless
addlines Useless,1,1+9
You can also specify “” for the field name if you don’t want any field sequenced.
addlines "",1,1+9
| 10.0 | Updated | Carried over from Panorama 6.0, but now the bump and copies parameters are optional, and allows "" for the field name if you don't want any field sequenced. |
