arraystrip
ARRAY
SEPARATOR
The arraystrip statement strips blank elements from an array.
array – the array to be stripped.
separator – the separator character.
This statement strips empty elements from an array.
arraystrip elements,cr()
arraystrip colors,","
For additional explanation and examples, see the arraystrip( function.
