setproceduretext
SOURCE
The setproceduretext statement changes the text of the currently open procedure.
source – the new text for the procedure.
This statement changes the text of the currently open procedure. Any existing text in the procedure will be wiped out.
This example creates a new procedure named Grand Total and fills it in with code to calculate the total of the Debit column.
makenewprocedure "Grand Total"
openprocedure "Grand Total"
setproceduretext {field Debit Total}
This statement must be used with a procedure window open.
