deleterecordandchildren
DATABASE
KEYFIELD
KEYVALUE
The deleterecordandchildren statement This deletes the current record from the active database and all the records in another database that have a value in the key field that is equal to the key value.
database – Name of database containing the “child” records.
keyfield – Name of the field you want to search in.
keyvalue – Value in records to be deleted.
This statement deletes the current record from the active database and all the records in another database that have a value in the key field that is equal to the key value.
This example deletes all the records from the My Contacts database that have a name in the Organization field that exactly matches the value in the Company field in the current record.
DeleteRecordAndChildren "My Contacts", "Organization", Company
In other words, it deletes the company from both the current database and the My Contacts database.
