stringreverse
RESULT
The stringreverse statement reverses the characters in a string of text. The original text is replaced in situ.
result – Text to be reversed (field or variable)
This statement reverses the characters in a string of text. The original text is replaced in situ.
This example checks to see if the text in field A is a palindrome (same text forwards and backwards).
local x
x=A
stringreverse x
if x=A
message "This is a palindrome"
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
