abortifstructurelocked
ACTION
The abortifstructurelocked statement Check if database structure is locked, if it is, notify user and stop program.
action – action user wants to perform.
This statement checks if database structure is locked (because the database is shared), if it is, notify user and stop program. This example will display the message Cannot insert field. if the database is shared.
abortifstructurelocked "insert field"
- automaticfieldname( -- returns an available field name.
- Field Blueprint Dialog -- examining and modifying the raw specification of a field.
- fieldalignment( -- returns the alignment of a database field.
- fieldformula( -- returns the formula associated with a database field.
- fieldnumber( -- returns the number of a database field (starting with 1).
- fieldpattern( -- returns the output pattern associated with a database field.
- fieldtypes( -- returns a carriage return delimited array with a list of the fields and field data types.
- fieldwidth( -- returns the width (in the data sheet) of a database field.
- hiddenfields( -- returns a list of hidden fields in the curent data sheet window
- visiblefieldnumbers( -- returns a data array of visible fields (by number) in the data sheet.
- visiblefields( -- returns a list of visible fields in the data sheet.
